loading udf in parallel sytem
Old   December 6, 2008, 07:03
Default loading udf in parallel sytem
tahere
hello my friends i have a problem in loading my udf. my project is dynamic mesh and i should compile my udf. in serial systems,i dont have any problem. in parallel system with 3 nodes i can build my libudf but when i want to load it,the computer hangs and i cant do anything more! i am sure that my directory is shared.
my udf is as follow:
#include "udf.h" static real v_prev; DEFINE_CG_MOTION(tnewback,dt,vel,omega,time,dtime) { Thread *t = DT_THREAD(dt); real dv;
/* reset velocities */ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P())
return;
if ( time <= 2)
{ dv = time ;
v_prev = dv;
/* set x-component of velocity */
vel[2] =10* v_prev;}
if ( time > 2 && time <= 5.1)
{ v_prev =20;
vel[2] = v_prev;}
if ( time > 5.1 && time <= 7.1)
{ dv = -10* time + 51 ;
v_prev = dv + 20;
vel[2] = v_prev;}
if ( time > 7.1 )
{ vel[2] = 0;
Old   December 6, 2008, 11:41
Default Re: loading udf in parallel sytem
bohis
Hi mate!
I have completely the same problem. I can build the udf library without any problem. Despite the working directory is shared, compute nodes on different machine cannot read it. It is very confusing, because there is report in fluent console like "the working directory is not shared! " and in real, it is shared. I am trying to cope with this. If I work it out, I will put it here. I would appretiate if you do the same, thanks! good luck! jack
Old   December 7, 2008, 18:37
CDE
Have you used a netwrok path to load the udf?
eg: \\computer\fluent\udf
Old   December 8, 2008, 02:59
bohis
thanks, I will try today! Then I let you know!
Old   December 8, 2008, 09:16
bohis
CDE was right, I forgot to use full the path to my udf library. For others: if you fail to load UDF in parallel, it could be because your UDF was compiled in serial Fluent.
thanks, bye!!
Old   December 13, 2008, 01:17
tahereh
hi friends! please explain more. where should i use the network full path? while i am compiling my udf i can't find anywhere to write fullpath!
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
Loading parallel udf Pablo FLUENT 7 March 6, 2011 10:25
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 12:59
UDF Error while loading Sujay S FLUENT 8 November 12, 2007 22:30
Problems with loading udf Mukund FLUENT 6 July 6, 2004 02:13
