November 12, 2013, 03:09 |
#21 |
Rep Power: 12 |
It could be that you don't have the additional license required, but the command prompt list should be:
define > models > addon-module > select option for MHD Cheers Stuart |
December 2, 2014, 23:46 |
#22 |
Dinushke
Rep Power: 12 |
You are getting that error, because you have to load a mesh before typing in the commands to load the MHD module.
Hope this helps, |
September 8, 2015, 12:17 |
#23 |
studentuofi
Rep Power: 10 |
hey i'm trying to activate this module as well. i type in the command properly but it says "invalid command [addon-module]"
when i type "help" and press enter it shows me the options and says that addon-module is disabled. see: |
September 8, 2015, 12:30 |
#24 |
studentuofi
Rep Power: 10 |
for me fluent says "invalid command [addon-module] and when i type "help" it says that that addon-module is disabled.
what can i do now? |
September 8, 2015, 19:22 |
#25 |
Dinushke
Rep Power: 12 |
You will FIRST have to load a mesh to the Fluent, then go to enable the MHD add-on. This feature is not enabled when the mesh is not loaded in Fluent. I have tested this.
September 9, 2015, 13:50 |
#26 |
studentuofi
Rep Power: 10 |
and how do i enable meshing? when i fire up fluent 16 i check mark the option for "meshing mode". is that correct?
if it is, i did that and when i type the command it still doesn't allow. it says "invalid command [define]. this is frustrating. need to get a flow sim done |
September 9, 2015, 20:18 |
#27 |
Dinushke
Rep Power: 12 |
No, it is not Mesh Mode. Just Start the Fluent normally (with double precision) and then click: File - Read - Mesh. Then load a mesh and once that has finished, Enter the commands.
April 13, 2018, 13:46 |
#28 |
erfan
Rep Power: 8 |
April 14, 2018, 06:21 |
#29 |
Dinushke
Rep Power: 12 |
Hi erfan1995,
Can you post the Text User Interface commands? Full list with the error. Regards, Dean |
April 14, 2018, 13:34 |
#30 |
erfan
Rep Power: 8 |
aha i had same problem but i solved it!
you should put your cursor at the end of texts in console and then press enter button once to go to next line and you will see ">" now type this: define/models/addon-module you will get the point! |
April 14, 2018, 13:36 |
#31 |
erfan
Rep Power: 8 |
hi dean993 i already found the right way thank you so much!
September 23, 2018, 02:59 |
#32 |
vektor
Rep Power: 7 |
hello, can you please tell me how you load the mhd module, i have fluent 19, and i read that i need to do a text command, i don't know how, i can do udfs and pretty much everything, but the text command is something i'vre never used thanks |
September 23, 2018, 21:14 |
#33 |
Dinushke
Rep Power: 12 |
Hi Vektor,
Load Fluent with a mesh or case file. Put your cursor on the console window and hit enter. You will get a set of text. Then paste "define/models/addon-module" and hit enter. Then you will get a set of addon modules. Type "1" and hit enter to activate the model. Go to the Models tree where you will find the MHD model visible. |
September 24, 2018, 03:45 |
#34 | |
vektor
Rep Power: 7 |
Hello, yup, it did work, thank you so much for the tip. |
September 24, 2018, 07:48 |
#35 |
erfan
Rep Power: 8 |
you should write in console define/models/addon-module
then press enter then press 1 it will appear in models now |
April 11, 2020, 10:48 |
ansys mhd problem
#36 | |
Manish Nath
March 23, 2022, 05:09 |
#37 |
First type "define" (without inverted commas)
Then type "models" Then type "addon-module" A list will appear like this: 0. None 1. MHD Model 2. Fiber Model 3. Fuel Cell and Electrolysis Model 4. SOFC Model with Unresolved Electrolyte 5. Population Balance Model 6. Adjoint Solver 7. Single-Potential Battery Model 8. Dual-Potential MSMD Battery Model 9. PEM Fuel Cell Model 10. Macroscopic Particle Model 11. Reduced Order Model Enter Module Number: [0] Type 1 on text interface and you will be able to activate MHD model. |
June 3, 2023, 11:28 |
Unload addon module
#38 |
SH
Rep Power: 2 |
I want to use another addon module, may I know how to remove the previous module? I have load module 3 and now want to load module 4. Thank you!
MHD Module | Ashish | FLUENT | 2 | November 18, 2017 03:40 |
Pemfc-addon-error message | vasanth parthasarathy | Main CFD Forum | 2 | November 25, 2013 15:55 |
MHD addon-module | Ergys Rexhepi | FLUENT | 1 | December 29, 2008 06:40 |
PEMFC addon module | vasanth parthasarathy | FLUENT | 0 | February 28, 2008 02:08 |
MHD Module | Benny | FLUENT | 0 | March 16, 2004 05:04 |
