power
Old   December 22, 2008, 09:40
Default power
hamane
How to calculate fluent on the power on a rotating stirred
Old   December 30, 2008, 09:36
Default Re: power
Mike
The way i use to calculate the power required by a rotating machine is the following: Report/Forces/Options-->Moments Then set the moment center and the rotating elements (i.e. in a fan you may have stationary and rotating parts, but you are only interested on the rotating ones, that is, the rotor blades and so on) When you clik "Print", on the Fluent text window will appear the required moment (be carefull: use the net moment) Finally, the product of the moment and the rotating speed will give you the Power required.
I hope have been usefull
Mike
PC power maalb FLUENT 0 June 13, 2008 06:34
Power Industry and CFD or other John Main CFD Forum 1 October 11, 2007 11:49
1/7 power law Eric Main CFD Forum 0 December 27, 2006 23:48
power bharat sharma FLUENT 0 October 8, 2005 05:09
Help; Power law method? Jay FLUENT 0 January 6, 2005 02:28
