generating sueface from 2 contours in gambit
Old   January 15, 2009, 16:55
Default generating sueface from 2 contours in gambit
violet
Is there a way for gambit to generate a surface from two contours, say, a circle on one side and a ellipsoid on the other?
Old   January 16, 2009, 00:26
Default Re: generating sueface from 2 contours in gambit
mAx
just with those 2 curves, I would say no.
But you can split each edge (at the middle for example), and create curves to join the two top surfaces.
Then create the lateral surfaces.
Old   January 16, 2009, 10:31
violet
thanks for you response. My opposing contour is actually more complicated than an ellipsoid. It is a rectangle with two half circles at the ends. What you suggested is what I was thinking to do but only with more splits.
Old   January 19, 2009, 03:43
mAx
yes you can try. More split will accurate the surface
Gambit, Matlab & generating a neutral file ".neu" francois Main CFD Forum 5 June 6, 2020 08:34
question on generating sliding mesh in Gambit multiphase-flow FLUENT 4 February 21, 2012 00:36
Help on generating 3-D object using Gambit Rucy FLUENT 2 November 4, 2005 05:49
Boundary Condition on the Free-Sueface Ferreira V.G. Main CFD Forum 5 August 13, 2001 06:40
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
