free surface and dip velocity
Old   January 12, 2009, 08:08
Default free surface and dip velocity
nazari
how can one simulate free surface with fluent to rersearch dip velocity phenomena?
Old   January 12, 2009, 08:17
Default Re: free surface and dip velocity
bohis
hi, in fluent, only VOF is able to simulate free surface flows..
Old   January 13, 2009, 01:42
Anastasios
what do you mean with "dip velocity"?
Old   January 13, 2009, 11:51
nazari
dip velocity means that due to secendary current in open channel ,max velocity doesn't occure at free surface. in outer region in open channel , turbulance dissipation is larger than its production so assuming zero gradiant for epsilon isn't sutable at there .
Old   January 14, 2009, 02:33
Anastasios
If you are interesting in the variation of the free surface then the VOF model is the only that can simulate the free surface. But i think that in this case you can only have two flow phases "Air" and "water". I dont think that you can apply a secondary phase that flows within the water.
If the secondary flow that you want to examine is say well underneath the free surface and posible variations in the free surface does not affect the velocity field of the secondary subaqueous flow, then you should define the free surface boundary with a "Symmetry" boundary condition or as a wall with zero shear and use the mixture or the eulerian multiphase model using two phases. Water being the primary phase and the secondary fluid being the secondary dispearsed phase.
Old   January 14, 2009, 04:09
nazari
secendry current in open channel result of damping and generation of turbulence fluctuation ,not a new phase enters the water phase. my question is that is it possible to modify the symmetry b.c?
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 09:54
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
Velocity on Free Surface Boundary Lin F.F Main CFD Forum 3 August 4, 2001 11:30
