January 15, 2009, 06:55 |
Sliding mesh problem
Hello all,
I'm currently performing a fan simulation in Fluent. I get a warning that non-positive volumes exsist when running unsteady with sliding mesh, and the simulation crashes. However, if I specify a MRF region instead of sliding mesh the simulation completes without warnings. What could be the reason for this and how to avoid it? Best regards |
January 15, 2009, 10:18 |
Re: Sliding mesh problem
That means your rotating volume is connected to your stationary volume. Both these volumes need to be disconnected (in GAMBIT) before sliding mesh can take place. What you can do is to convert your MRF case to a sliding mesh case automatically. This is done via TUI:
Grid/modify-zones/mrf-to-sliding-mesh It will then prompt you to input the ID number for your rotating domain. You should be able to do sliding mesh simulation without any problems now. Hope that helps. |
Sliding mesh model problem | Usman | FLUENT | 9 | January 30, 2015 05:37 |
Sliding Mesh Problem | CC | FLUENT | 1 | February 8, 2009 23:26 |
sliding mesh problem.help me. | khairel khatab | FLUENT | 0 | August 3, 2006 08:51 |
sliding mesh problem | annie | FLUENT | 0 | November 5, 2004 07:47 |
sliding mesh problem | Devin | CFX | 1 | January 4, 2004 17:12 |
