UDF Compilation Error
Old   February 2, 2009, 15:22
Default UDF Compilation Error
Karthik
Hello all,
I'm working in a case that needs an udf to control the viscosity of fluid. I compile the udf and the following error message appears,
ERROR: Set_material_property: null user defined function name
I would be grateful if anybody could help me to solve this problem.
Thanks in advance
Karthik. K.
Old   February 8, 2009, 16:38
Default Re: UDF Compilation Error
KJ Larsen
Hello Karthik
As it sounds as if it's complaining about your UDF's name:
Try set_material_properties in the name given as an arguments for the (I assume) Define_Property UDF, I do not believe capitals are allowed.
Hope it's this simple. Kris
Old   February 9, 2009, 11:17
Karthik
Hi Kris,
Thanks a lot for the reply. I tried changing the name but it did not work. This is UDF I am using can you please let me know if some thing is wrong with it?
#include "udf.h" #define n 0.67 #define alph 1.0 #define mu 0.0042
DEFINE_PROPERTY(power_law_model,cell,thread) {
float trace;
double visc;
float u[3], v[3], w[3];
int j;
for(j=0;j<3;j++)
u[j]=C_U_G(cell,thread)[j];
v[j]=C_V_G(cell,thread)[j];
w[j]=C_W_G(cell,thread)[j];
} trace= 0.5*(2*pow(u[0],2)+pow(v[0]+u[1],2)+2*pow(v[1],2)+pow(v[2]+w[1],2)+2*pow(w[2],2)+pow(w[0]+u[2],2)); visc=0.5*mu*pow(1+alph*trace,0.67); return visc; }
Old   February 9, 2009, 11:38
KJ Larsen
Hello Karthik
I cannot see any immediate problems in that code but it's very difficult without any clues. Surely the error has changed; since Set_material_property is not in this code. Are line numbers given?
Kris
Old   February 9, 2009, 11:42
Karthik
Hi Kris,
It does'nt show the line numbers, but this is the error it shows when I try to compile it,
Error: Set_Material_Property: null user-defined-function name Error Object: #f
I tried changing the name but it did not work. Any idea of what else can I do?
Thanks, Karthik.
udf compilation error sdp FLUENT 0 February 5, 2009 02:58
UDF compilation error Hari FLUENT 0 February 22, 2008 13:40
Compilation error skabilan OpenFOAM Installation 1 September 17, 2007 13:33
Compilation error CFX 11 Beth CFX 0 July 26, 2007 19:36
Compilation error Karthick FLUENT 5 April 16, 2004 13:36
