Adapt mesh and F_CENTROID
Old   February 13, 2009, 09:50
Default Adapt mesh and F_CENTROID
Pifou74
Hello, when I adapt mesh in fluent (hanging nodes) and try to use F_CENTROID macro in a UDF after, I have a memory problem. Has someone already meet this problem ? If yes is there a solution?
Thanks
Pifou
Old   February 23, 2009, 05:19
Default Re: Adapt mesh and F_CENTROID
Ralf Schmidt
Hi!
grid adoption in fluent with hanging nodes results in a very big number of cells and that causes your memory problem.
Unfortunately, fluent halves the cell in EVERY direction when adapting with hanging nodes. So you have times 4 cells in 2D and times 8 cells in 3D.
I had that problem as well.. wishing, that there would be a possibility to adapt only in one direction.
best wishes! Ralf
Old   February 25, 2009, 09:27
Pifou74
Thank you for your answer... Happy to see that I am not alone!! If I find a solution I will post it.....
Pifou
F_CENTROID co2 FLUENT 2 September 1, 2011 01:49
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 14:11
adapt-region Giulia Valerio FLUENT 0 November 19, 2007 05:02
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
Adapt Y+/Y* Christine FLUENT 0 February 22, 2006 10:27
