error in loading valve.c of dynamic mesh
Old   February 24, 2009, 01:35
Default error in loading valve.c of dynamic mesh
Pavan
Hi all
I tried to solve dynamic mesh (valve) problem in fluent6.3.26. while I am loading the UDF (valve.c) it is showing an error massage like below.
" Deleted old libudf\win64\2d\libudf.dll
1 file(s) copied. (system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\win64\2d\makefile")
1 file(s) copied. (chdir "libudf")() (chdir "win64\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done. "c:/documents and settings/tb13073/desktop/dynamic_mesh/dynamic_mesh"
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()"
please give me the solution for this error,
Thanks and regards, Pavan Kumar.
Old   February 24, 2009, 03:15
Default Re: error in loading valve.c of dynamic mesh
Rishikesh
Dear Pavan
It seems ur UDF is having a problem reading the library 'udf.h'
check ur C program
most of the errors associated with UDFs compilation are syntax errors
feel free to ask any doubts
Regards
Rishikesh
Old   February 24, 2009, 03:56
Pavan
Hi Rishikesh,
Thankyou very much for your replay. The thing is I am not much aware of C code. If you have the code for this problem please send it to my mail ID: yours.pavan@yahoo.co.in
Thanks and regards Pavan.
Old   February 25, 2009, 00:21
Rishikesh
no man
i do not have the code
u can check up which macro they hv used for the UDF.
u can also go through the Fluent 6.3 UDF manual
its avaliable on the net in PDF format
Regards
Rishi
Old   February 25, 2009, 00:22
Rishikesh
no man
Regards
Rishi
Fatal error whilst loading an icem mesh Simon Mizzi FLUENT 0 February 28, 2009 16:55
Dynamic mesh error samnetmoon FLUENT 0 May 19, 2008 12:45
Dynamic mesh error Sham FLUENT 2 June 13, 2007 04:23
ERROR WHEN ITERATING in dynamic mesh bijan FLUENT 0 June 10, 2006 03:11
ERROR WHEN ITETATING in dynamic mesh bijan FLUENT 0 June 7, 2006 05:53
