modelling a rotating cylinder in fluent?rply asas
Old   February 14, 2009, 15:52
Default modelling a rotating cylinder in fluent?rply asas
taimoor
to model a rotating cylinder with some angular velocity either we need to do dynamic meshing or it only needs some steps in fluent?Does static meshing not enough to do so.plz reply soon.
Old   February 15, 2009, 18:27
Default Re: modelling a rotating cylinder in fluent?rply a
Davy
you may use single or multiple rotating reference frame approach or sliding mesh approach in Fluent.
Old   February 16, 2009, 07:00
srihari
i dont think u need udf to do this becoz u can make it as a wall and make it moving wall..if the mesh is rotating then u have to create a udf for dynamic mesh...thi is ho i can help u..i just finishd a 2d rotary vane pump problem after long struggle..so if u cpould elaborate ur problem..can help u more.thanks regards hari
Old   February 27, 2009, 07:03
Ryma
you should use the MRF (moving refrence frame),you must have a cylinder around your disc that you specify as fluid and then in the fluid panel you set moving reference frame rather than stationnary.and you can change the unit of the rotating frame in define-units'angular velocity Hope it helps
Rotating cylinder raul FLUENT 3 February 1, 2015 05:48
how can i make rotating cylinder in gambit& fluent mohamed FLUENT 1 April 1, 2008 03:28
Rotating Cylinder IGE Jason Mc Beth FLUENT 0 January 23, 2008 07:02
Rotating Cylinder Nick Siemens 1 June 21, 2006 06:42
Rotating cylinder Johnny Main CFD Forum 5 December 7, 2004 09:55
