Wall Material
Old   March 3, 2009, 09:59
Default Wall Material
Maple
I am working on the non-premixed combustion problem. I need to define a material for the combustion chamber wall and its other properties like thermal conductivity, density, etc.
When I go to Define> Boundary Conditions and set the boundary condition for the wall, the material there already mentioned (by default) is Aluminum. How do it change it to some other material? I am not able to do that.
Also I want to know when I go to Define > Material option,and select a material... what material is this for? is this for the wall material or the fluid inside the chamber?
Please let me know how do I define the material for the combustion chamber wall?
Thank you so much.
Old   March 3, 2009, 10:46
Default Re: Wall Material
Laci
Hi Maple, Go to Define\Materials Here, click on the 'Fluent Database'. Choose 'Solid' from the drop-down list on the right. Than on the left choose the appropriate material. Click on it, then click 'Copy' in the bottom of the panel. After this, you will see you material in the drop down list when you want to set the wall material. In the Materials panel you will see all the materials, you have in your system. In the drop down list you can Choose Fluid, Solid, Inert-particle... (but you have to activate some model for the last one...) I hope I could help you.
Old   March 3, 2009, 12:05
Ev
Hi Laci,
Thank you very much for the reply.
I tried to do what you told me, but the solid material (SiC) I want to select is not in the Fluent Database list. What should I do now?
Thank you.
Old   March 3, 2009, 20:43
yufeng
you shoulu definen a new material
Old   March 13, 2009, 05:39
Default Transient Heat Transfer Analysis
Bharat
I want to analyse Time dependent Heat Flow Analysis.
The problem has multiple time step with different heat input value.
Can anybody suggest how to do that using Fluent.
What kind of BC can be used and what precaution to be taken care in order to ensure correct output.
Thanks
Bharat
about the set up of "oil" material nick CFX 2 April 12, 2008 08:59
New Material M.E. FLUENT 6 June 11, 2007 10:06
mixture type material as a phase material Pablo FLUENT 1 January 25, 2007 10:54
Add New Material davis FLUENT 1 September 4, 2003 06:51
wall material problem? Eric FLUENT 2 December 22, 2000 03:57
