Boundary condition for vibrating disk
Old   March 4, 2009, 22:40
Default Boundary condition for vibrating disk
Apple
I'm doing about the ultrasonic piezoceramic disk vibrating under water in the tank with no feeding water. Then waves propogate from the disk upward to water surface. The thing is I am not sure how to set the boundary condition at the disk. Could it be velocity inlet or deforming wall? The disk motion is in y direction (2D); the deformation is governed by y(t)=asin(2*PI*f*t)and velocity is Vy(t)=2*PI*f*a cos(2*PI*f*t). Which one should I use?
Thank you very much....
Old   March 5, 2009, 03:47
Default Re: Boundary condition for vibrating disk
mAx
Let your disk as wall in boundary condition.
Enable deforming mesh
describe the motion in an UDF
then in the deforming mesh panel, choose your udf your describing the motion of your disk
Old   March 5, 2009, 06:30
Apple
Thank you very much Max,
In wall boundary condition panel, do I need to put any udf motion for the wall or just leave it as 0 and only add udf in deforming mesh panel? I have to enable dynamics mesh,right? and then specify the zone by choosing deforming or User-define under type? One more thing I'm not quite sure how to write udf, should I use Define_Geom or define_grid_motion? Can anyone help me suggesting how to write it, I dont know that much about writing udf.
Old   March 5, 2009, 07:38
mAx
set your disk as wall (default set up)
in Deforming mesh, set your disk with rigid body motion, and then Motion attribute with your udf, in which you should use DEFINE_CG_MOTION()
In the tutorials, there is one about MDM with an udf. Get inspire in it
Vibrating Airfoil Analyses gtg627e OpenFOAM Running, Solving & CFD 3 December 4, 2007 12:39
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 12:21
Vibrating Wall Leigh FLUENT 4 July 13, 2006 03:33
UDF for vibrating membrane Sherif FLUENT 0 November 9, 2004 10:17
Vibrating / Deforming Wall UDF Qureshi FLUENT 2 January 16, 2004 04:48
