problem in drag force calculation
Old   March 12, 2009, 04:17
Default problem in drag force calculation
M.Hasib
hi i am facing problems in claculating drag force over NACA0012 profile. problem specs are water flow over foil at 2m/sec velocity. angle of atack zero. as i knew from theoratical study at zero angle of atack the lift should be zero for NACA0012 as it is symetric. can u guide me in this regard. thanks
Old   March 16, 2009, 12:01
Kostas
mech5190 is on a distinguished road
Yes, if you have symetrical foil then the zero lift ,it is showed at zero angle.
To find the drag, you will go in fluent: Report->Forces.
Here you will opt the specifications of your foil and you will push plot.
mech5190 is offline   Reply With Quote
Calculation of Drag Force per unit Length Mohammad Faridul Alam CFX 4 January 11, 2013 07:19
Drag force in CFX anand CFX 0 November 8, 2008 04:44
Drag force Iain CFX 3 October 12, 2008 09:00
Drag force Iain CFX 0 September 21, 2008 03:16
UDF for force calculation Sham FLUENT 0 May 27, 2007 22:33
