output the msh from CFX mesh to Fluent
Old   March 12, 2009, 10:29
Default output the msh from CFX mesh to Fluent
Jiuan
I created the mesh using CFX meshing, and got a msh file. When I read this file into Fluent, it alwasy failed. The error message looks as follows
--------------------------- Building...
grid, face[0]->cell0[16777216] on thread 6 out of range (0<=cell<18135). Error: Build_Grid: grid error.
Clearing partially read grid.
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () ---------------------------
FYI, my computer is 64-bit and I am using 64-bit workbench.
Thank all.
Old   March 13, 2009, 02:08
Default Re: output the msh from CFX mesh to Fluent
zongtwi
Do you have the 'advanced meshing' application in workbench? if you do, the workbench prject page, choose your CFX mesh file .cmdb, and on the left pane, choose 'Poceed to advanced Meshing'. Once opened in advanced meshing, go to the output tab, and choose to export to FLUENT. This should be able to give u a .msh file for FLUENT.
Hope that helps.
Output Matrix of Temperatures Across Mesh Ray FLUENT 2 February 5, 2009 18:20
How to output GridGen mesh to Adina-F? cfd Pointwise & Gridgen 7 May 27, 2008 16:23
Problem with Output to .cfx5 mesh Ben CFX 4 January 24, 2008 17:47
Gambit mesh output Jason FLUENT 4 April 3, 2007 12:35
ICEM tet mesh output jemteo CFX 1 August 15, 2004 18:34
