March 9, 2009, 13:12 |
MPICH2
I have a problem with the combination Fluent+Mpich2 for work in paralel mode.
I don't know if the users need to be network users or they can be locals of the machine. With local users don't work. If I launch fluent from Fluent launcher seems to function properly but when I open a case+data show me an error when reads it: read-case&data: :invalid machine Thanks |
March 11, 2009, 18:40 |
Re: MPICH2
Alfonso -
I have this EXACT same problem. I am running a new XEON-based workstation with Vista-64 installed. It took a while to find a version of the MPICH2 that runs properly, but I downloaded one from the Argonne website that did work finally. I am only trying to run MPI on this single machine (8 threads), so my host file is very simple, like: graddome03x graddome03x graddome03x graddome03x graddome03x graddome03x graddome03x graddome03x I finally got no errors to show when I use the "check" button in the launcher - and then got it to "successfully" launch FLUENT, only to have it give the following error when I try to open a file: Loading "C:\Fluent.Inc\fluent6.3.26\lib\fl114-64.dmp" Done. Warning: -path flag not specified. Defaulting to -pathC:\Fluent.Inc Welcome to Fluent 6.3.26 Copyright 2006 Fluent Inc. All Rights Reserved Loading "C:\Fluent.Inc\fluent6.3.26\lib\flprim1119-64.dmp" Done. : Error: read-case-data: invalid machine Error Object: #f That last part occurs when I try to open a file! I will tell you when I figure anything else out - meanwhile, if anybody else can guess what stupid mistake I'm making, please reply!!! Cheers, -Daniel |
March 13, 2009, 11:48 |
Thank you so much Daniel...
Hello Daniel First all I want to thank you so much for answer me and help me I will try to do what you advice me and we could be in touch I trying to do a cluster with four Computer to run 4000000 elements so I hope it work Kindly Regard Alfonso
OF15x with MPICH2 | elisabet | OpenFOAM Installation | 6 | August 25, 2009 23:19 |
CFX11 MPICH2 local parallel for windows | mohanrao | CFX | 3 | March 31, 2009 10:01 |
OpenFOAM and MPICH2 | msrinath80 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2008 12:20 |
mpich2 build for hpf | taw | Main CFD Forum | 0 | April 6, 2008 03:34 |
MPICH2 and dual-core | Ford Prefect | Main CFD Forum | 4 | July 4, 2006 21:16 |
