How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh
Like Tree6Likes
  • 1 Post By O.D.Y.
  • 1 Post By O.D.Y.
  • 1 Post By O.D.Y.
  • 1 Post By O.D.Y.
  • 2 Post By -mAx-
Old   March 22, 2009, 16:43
Default How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh
ruiyang
tomyangbath is on a distinguished road
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh?
I want to do dyanamic mesh in Fluent. Just a single paddle rotate. I want create boundary layer around the paddle, and let the boundary layer moving with the paddle without remeshing. The remeshing only happens outsite the boundary layer. So anyone know how to set this boundary layer in to a zone or something for achieve this?
Thanks a lot
Tom
tomyangbath is offline   Reply With Quote
Old   March 22, 2009, 22:55
paka is on a distinguished road
Well, I don't know what you really want to do, but I had some problems with boundary layer within dynamic meshes. My boundary was moving just in one direction lets say in x direction, so what I figured out my model had trouble with cell adjustment around the wall area, I was using layering method which results in cell collapse.
At the end I figured out area without boundary layer in this region did no make too much difference, since I was interested in result far away from what moving boundary was doing.
Hope this helps.
paka is offline   Reply With Quote
Old   March 23, 2009, 05:13
ruiyang
Thanks paka, but I still looking for the answer of the boundary layer. anybody can help? thx
Old   March 23, 2009, 17:42
O.D.Y.'s Avatar
O.D.Y. is on a distinguished road
Hi there,
I'm calculating airfoils with boundary layers which shall not deform when i move the blade. Therefore I created a face around the blade which covers the boundary layer and which does not deform anyway so the deformation only takes place in the rest of the flow domain. this works quite good...
abstractcola likes this.
O.D.Y. is offline   Reply With Quote
Old   March 23, 2009, 20:22
panda is on a distinguished road
Using the sliding mesh approach may protect your boundary layers.
panda is offline   Reply With Quote
Old   March 24, 2009, 03:59
ruiyang
Thanks O.D.Y for ur answer, but I still not clear how can u create a face exactly has the same size at the boundary layer? Does it matter if the face is just a little bit bigger or smaller than the boundary layer? Hope for ur valueless answer!
Old   March 24, 2009, 04:00
ruiyang
Originally Posted by O.D.Y. View Post
Hi there,
Old   March 24, 2009, 04:10
O.D.Y.'s Avatar
Well I'm of the opinion, that it doesn't matter if the face is a little bit bigger than the BL reaches. I mean your main intend is to keep the BL mesh constant close to the wall and if you extend the constant area a little bit further the only thing you have to take care for is that you have enough mesh in the rest of the domain left to cover the mesh deformation due to the body movement.... Well in my case I'm doing steady state calculations where I can estimate the boundary layer thickness and create another mesh afterwards with the proper face sorrounding the blade... Honestly this is an easy task for 2D calculations but the effort increases for 3D to make up a proper flow domain in gambit....
Old   March 24, 2009, 04:15
Well... I never did it, but it seems you can define BL faces as ones which move similarly to body edges. Don't you think this might work? So the BL part is so saying "rigid" with body deformation and only the part of the mesh outside BL should deform. I think this might also work in 3D.
Old   March 24, 2009, 05:00
O.D.Y.'s Avatar
Yeahh that should work. Well I did this in 2D, meaning the "BL-face" moving as rigid body and deforming the mesh outside, I just mean its a bit more effort to make up the model in 3D concerning my cases ;-) but i guess this is far better than changing smoothing and remeshing parameters until it works "somehow good"....
mhoseinm likes this.
Old   March 24, 2009, 15:49
ruiyang
Hi O.D.Y, I tried. I created a bl around my moving object, then created mesh for the rest of domian, then created a face just cover the BL. Finally, for the zones setting, I set the face (which cover the BL) to Continuum type as Fluid. Then I loaded the mesh in Fluent, but I could not find the zone. I also tried set the face as the Boundary zone type as Wall, still could not find this zone in Fluent. Can u tell which part I did wrong? Or could you sent me a simple file u did please? my email: yangshangy@hotmail.com Thanks a lot.
Old   March 25, 2009, 05:50
ruiyang
anybody can help, please
Old   March 27, 2009, 12:18
O.D.Y.'s Avatar
Actually you should be able to find the boundary face in the boundary conditions menu.... and of course you should define the boundary face as fluid. And you need to make sure that the interfaces between the boundary face and the face for the rest of the domain have the same interface edges. That should work because I'm doing it that way without problems.... cheers
Old   March 28, 2009, 09:23
ruiyang
Thx O.D.G., but can u tell me how to find the boundary face please? Because I can not find it in the boundary condition menu. Many thanks.
Old   March 28, 2009, 14:21
-mAx-'s Avatar
Maxime Perelli
In 2d-->
I would create a curve surrounding your airfoil.
The distance to the airfoil should be greater than your BL.
Then split your domain with this curve.
Mesh all your domain and add your BL.
Then in BC, go to zone panel and create a surface zone as fluid (in will be your rigid body motion's surface).
In fluent you should be able to set this one as rigid body in MDM panel.
For 3d, replace curve with surface, and surface with volume.
souhail and mhoseinm like this.
Old   March 28, 2009, 15:23
ruiyang
Originally Posted by -mAx- View Post
In 2d-->
Thanks MAX, it works. Brilliant, thanks a lot
Old   January 18, 2012, 04:47
Default Hi
  #17
mojtaba
mojtaba1365 is on a distinguished road
Hello guys,
I wanna simulate a moving body in a fluid. But how can i simulate it? the body should move in the fluid!!
please help me...
Thanks very much
mojtaba1365 is offline   Reply With Quote
Old   March 25, 2016, 04:36
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
where in dynamic mesh do we specify not to move/disturb the boundary layer?
Shamoon Jamshed is offline   Reply With Quote
Old   October 12, 2016, 06:57
Far
Sijal
BL is moving as rigid body
moving boundary / mesh John Main CFD Forum 1 May 8, 2008 10:28
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 11:33
can fluent capture BOUNDARY LAYER of POROUS zone? Alex FLUENT 0 April 22, 2006 07:14
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
