Is it true ??
Old   March 26, 2009, 14:46
Default Is it true ??
R. Roy
rr123 is on a distinguished road
dear all,
is it true that thread IDs of surfaces created in post-processing panel (i.e. NOT made from GAMBIT) cannot be accessed in UDF ?
hoping for a reply.
best regards.
rr123 is offline   Reply With Quote
Old   March 28, 2009, 06:03
mbernard is on a distinguished road
hello
the geometric entities you have create in Fluent through post processing panel must not be know in the mesh,i.e. they don't contain any node...I think you can't use it for computation in an UDF. Anyway, adding some surfaces for post processing in Gambit is a good way to process, cause it avoid some surface creation troubles.
Regards
mbernard is offline   Reply With Quote
Old   March 28, 2009, 18:13
panda is on a distinguished road
it would be troublesome if the created surface is dynamically changing
panda is offline   Reply With Quote
Old   March 28, 2009, 18:41
R. Roy
yes, i understand the point you are making bernard. it is true.
but i agree with panda also.
i mean, how could i know which surfaces could be interesting from before hand (i.e. from the time of making the mesh)
i mean this could be too much demanding of the flow knowledge beforehand isn't it ?
anyways, i think i have some idea wherein i could use a loop over all the domain so that i could choose the cells of the surface position i need. maybe this would help.
[Other] True Grid for OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 2 November 20, 2022 17:52
CFX: what is "A true volume-porous media model?" whiz CFX 28 April 16, 2019 08:14
TESTING OF TRUE CONVERGENCE THROUGH FLUX REPORT AKI FLUENT 0 January 18, 2009 05:25
Are these rules by Patankar true? zonexo Main CFD Forum 3 November 11, 2005 04:01
difference between false and true transient mahesh prakash Main CFD Forum 1 January 21, 1999 13:45
