November 4, 2004, 04:50 |
UDF for source term in momentum equation
Hi all I write a UDF for source term in momentum equation this source term is : A.( du/dx) , where u is the x-component of the velocity ...
please can somebody tell me what is the mistacke I have do in this UDF DEFINE_SOURCE(xmom_source, c, t, dS, eqn) { real source; source = A*C_DUDX(c,t); return source; } |
November 4, 2004, 05:50 |
Re: UDF for source term in momentum equation
you haven't defined A?
November 5, 2004, 03:26 |
Not only that you have not defined A, but also you have to add one more statement namely:
dS[eqn]=0; Good Luck to you. Sun |
November 6, 2004, 04:26 |
A is a constant
November 9, 2004, 04:27 |
Yes, A is a constant but you must define it. for example; DEFINE_SOURCE(xmom_source, c, t, dS, eqn) { real source; int A; A=22; source = A*C_DUDX(c,t); dS[eqn]=0;
return source; } "A" can be real or integer. It is up to you. Hope I can help you. Bowling |
November 10, 2004, 06:06 |
Hi ,Bowling , but why dS[eqn]=0 ? dS[eqn]=dS/dU
November 12, 2004, 00:58 |
You are misunderstand. dS[eqn] in here means d(source)/d(your parameter) eg. x-momentum, your parameter is U your source is A*(dU/dX), so dS[eqn] is second derivative of dU/dX equal d^2U/dX^2. Diff your source by your parameter.
dS[eqn] is the way to define your source solving. I don't know how to explain. You can read more infomation in fluent document. Bowling |
November 13, 2004, 03:33 |
Hi Bowling , should i use UDS for calculating dS[eqn] ?
November 15, 2004, 00:20 |
#9 |
I don't think so. It is the condition in DEFINE_SOURCE. It is the way to solve in the finite volume method not a scalar.
Bowling |
May 30, 2014, 11:34 |
#10 |
Rep Power: 14 |
how do we know this formula: source = A*C_DUDX(c,t);
I have a equation for velocity gradient: dudz=const However, I have no idea how to transfer my equation into this kind of form: source = A*C_DUDX(c,t); Thanks |
add source term to energy equation by udf | tomas | Fluent UDF and Scheme Programming | 7 | September 10, 2013 02:08 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
UDF Time-dependent term in source | Ronnfors | FLUENT | 0 | October 16, 2009 11:25 |
UDF Source Term Units? | Brian | FLUENT | 1 | October 24, 2005 09:15 |
bouyancy term in epsilon equation | Michael | Main CFD Forum | 1 | June 25, 1999 10:20 |
