April 16, 2009, 11:22 |
How to read IC Engine cylinder pressure
sreenivasulu
Dear Sir,
I am trying to read cylinder pressure of an IC Engine, I could model the combustion chamber and run the case in FLUENT, but i could not read cylinder pressure. Some body please help me which option i should use to read this. m. sreenivasulu Last edited by mslu544; April 17, 2009 at 23:50. |
April 18, 2009, 00:35 |
you can use volume integrals (in report menu) to integrate the pressure inside the cylinder and get the values.
also if you are willing to get the calculated value for different crank angles, you can set the same settings in the define/animation before running the case. |
April 19, 2009, 07:19 |
ICE simulation from the FLUENT tutorial
Yashodeep
I am new to FLUENT and i m trying to run the ICE cold flow simulation tutorial given by FLUENT. I followed all the steps given but still I am getting error after I apply the initial conditions: WARNING: Unassigned interface zone detected for interface 21 WARNING: Unassigned interface zone detected for interface 26 Error: Init_Flow: unassigned interface_zones Error Object: () What could be the possible problem is it with the mesh or case set up? I assigned all the zone as per the tutorial. Please help me with this. Thanks, Yashodeep |
May 19, 2009, 09:19 |
sreenivasulu
[QUOTE=yash;213425]Hi,
I am new to FLUENT and i m trying to run the ICE cold flow simulation tutorial given by FLUENT. I followed all the steps given but still I am getting error after I apply the initial conditions: WARNING: Unassigned interface zone detected for interface 21 WARNING: Unassigned interface zone detected for interface 26 Error: Init_Flow: unassigned interface_zones Error Object: () What could be the possible problem is it with the mesh or case set up? I assigned all the zone as per the tutorial. Please help me with this. I have seen ur message today initialization problem- it might be at interface_zones if u can send the soft copy (pdf) i can suggest u. sreenivasulu |
May 19, 2009, 16:49 |
Yashodeep
thanx i was able to fix it.. there was problem with the boundary conditions
How to read pressure from a designated path | jennyrui2008 | OpenFOAM Running, Solving & CFD | 0 | December 4, 2008 04:48 |
Input flowrate and outlet pressure in a cylinder | philippe | FLUENT | 0 | June 23, 2008 04:48 |
Pressure Condition | sidd | Siemens | 0 | April 2, 2007 09:31 |
base pressure for circular cylinder | fpz | Main CFD Forum | 7 | June 20, 2005 21:30 |
pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 10:52 |
