plane Poiseuille flow:-( velocity profil!!!!!!
Old   April 22, 2009, 04:31
Question plane Poiseuille flow:-( velocity profil!!!!!!
gina
gina is on a distinguished road
I have tried to reproduce the plane Poiseuille configuration with Fluent .I have begun with laminar 2D test case, I specified the boundary condition as follows, at the inlet à velocity = velocity magnitude = 30 m/s (in x direction), at the outlet à zero pressure outlet, at the top and back wall à no-slip stationary.
After running, the velocity profil is not parabolic
Could you please explain what went wrong
gina is offline   Reply With Quote
Incompressible laminar poiseuille flow samarth OpenFOAM Running, Solving & CFD 20 July 13, 2010 03:38
calculating mass flow rate from exported velocity values Sasha FLUENT 0 April 6, 2009 16:07
Basic Poiseuille flow simulation question Ashish Main CFD Forum 0 October 2, 2007 13:05
Gravity Flow Velocity Computation Jerry McHugh Main CFD Forum 1 March 16, 2007 13:24
Can reversed flow occur at velocity inlet Bcs. kanok FLUENT 1 September 30, 2003 11:54
