display of time_step number or size or current_time |
April 24, 2009, 09:47 |
Erdem Demir
Rep Power: 17 |
Hi;
is it possible to display in a separate window (like residuals or surface monitors), time step number and size or current time of flow when running an unsteady state flow? Thanks |
April 24, 2009, 10:01 |
Maxime Perelli
Rep Power: 41 |
if you display something each x-time steps (solve/execute commands...), than you get it with the current time (at the bottom left)
In memory of my friend Hervé: CFD engineer & freerider |
April 24, 2009, 10:23 |
Erdem Demir
Rep Power: 17 |
thanks -mAx- I know that what I would like to see a bigger representation like bigger fonts and a separate window. can it be done using a command or a journal perhaps?
April 24, 2009, 11:06 |
Maxime Perelli
Rep Power: 41 |
I don't think you can display the current time alone in a display window.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
