May 2, 2009, 04:55 |
WALL and WALL shadow
Eric
Rep Power: 17 |
hello!
I define BC WALL (one side is solid,the other is fluid)in gambit,but i fine WALL and WALL shadow when defining BC in fluent. can anyone tell me the meaning of wall shadow? my purpose is to define the temperature of the wall.how should i define the two sides of the interface? thanks!!!!!!!!!! |
May 2, 2009, 05:47 |
Contrarian
Rep Power: 17 |
The wall and wall-shadow correspond to the boundaries for the fluid and solid respectively. You can specify independent thermal boundary conditions for the fluid side and the solid side but in most situations you would want to specify a "coupled" boundary condition (heat flux is conserved across the boundary) and specify the thermal boundary conditions (e.g. constant temperature) at the outer wall of the solid region.
May 2, 2009, 06:39 |
Ralf Schmidt
Rep Power: 17 |
CFD - nothing but Colourful Fluid Dynamics |
May 2, 2009, 20:58 |
#4 | |
Eric
Rep Power: 17 |
i still have two questions: 1,wall and wall shadow which is solid BC,and which is fluid BC? 2,i want to define the temperature or heat flux in the solid side ,then should i define the other BC as "couple"? thanks for your regard! |
May 3, 2009, 00:08 |
Contrarian
Rep Power: 17 |
You can find the "adjacent cell zone" by opening the BC panel.
However, you cannot specify "coupled" BC at the wall and "temperature" at its shadow. By specifying "coupled", you are stating that the flux on the solid side is the same as the flux on the fluid side. There is no additional input needed at that point. You will need to specify temperature or heat flux boundary condition at the outside wall of the solid. Alternatively you may choose not to model heat transfer in the solid in which case you can as well delete the solid zone. |
May 3, 2009, 09:44 |
#6 | |
Eric
Rep Power: 17 |
my email is daozhenxu@hotmai.com welcome to contact me ! it would be my honnor to know your email! |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
wall shadow problem | paul | FLUENT | 5 | November 16, 2013 13:46 |
wall shadow | amar | FLUENT | 1 | February 5, 2010 06:07 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
