April 24, 2009, 10:32 |
Surface Monitor Question
Rep Power: 17 |
I am running an unsteady simulation in the 2D domain that is shown below, and I want to monitor the max pressure, max density, and mass flow rate at everyone of the blue lines (surfaces that I created in Fluent). I was hoping to do this without having a separate surface monitor file for each line and parameter. I tried to combine all of the pressure terms for each surface into one file, but all it gives me is some average (I think). Does anyone have any suggestions on how I can efficently monitor these surfaces without having 30 different monitor files? Thanks in advance
April 24, 2009, 10:51 |
create a journal file with report -> surface integrals
Ralf Schmidt
Rep Power: 17 |
Hi!
you might use: -> report -> surface integrals - report type: vertex (or facet) maximum - field variable: pressure - surface: the lines, you are interested in. That gives you the maximum of the pressure on every line. Now, you can program the same with the TUI and create a journal file. Best wishes! Ralf
CFD - nothing but Colourful Fluid Dynamics |
April 24, 2009, 16:39 |
Rep Power: 17 |
Thanks Ralf, I'll try that.
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 06:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
