WALL and WALL shadow
Like Tree1Likes
  • 1 Post By contrarian
Old   May 2, 2009, 04:55
Default WALL and WALL shadow
Eric
duaiduaihu is on a distinguished road
hello!
I define BC WALL (one side is solid,the other is fluid)in gambit,but i fine WALL and WALL shadow when defining BC in fluent.
can anyone tell me the meaning of wall shadow?
my purpose is to define the temperature of the wall.how should i define the two sides of the interface?
thanks!!!!!!!!!!
duaiduaihu is offline   Reply With Quote
Old   May 2, 2009, 05:47
Contrarian
contrarian is on a distinguished road
The wall and wall-shadow correspond to the boundaries for the fluid and solid respectively. You can specify independent thermal boundary conditions for the fluid side and the solid side but in most situations you would want to specify a "coupled" boundary condition (heat flux is conserved across the boundary) and specify the thermal boundary conditions (e.g. constant temperature) at the outer wall of the solid region.
seali33 likes this.
contrarian is offline   Reply With Quote
Old   May 2, 2009, 06:39
Ralf Schmidt
Ralf Schmidt is on a distinguished road
see also:
http://www.cfd-online.com/Forums/flu...tml#post214529
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   May 2, 2009, 20:58
Eric
thanks!friend!
i still have two questions:
1,wall and wall shadow which is solid BC,and which is fluid BC?
2,i want to define the temperature or heat flux in the solid side ,then should i define the other BC as "couple"?
thanks for your regard!
Old   May 3, 2009, 00:08
Contrarian
You can find the "adjacent cell zone" by opening the BC panel.
However, you cannot specify "coupled" BC at the wall and "temperature" at its shadow. By specifying "coupled", you are stating that the flux on the solid side is the same as the flux on the fluid side. There is no additional input needed at that point. You will need to specify temperature or heat flux boundary condition at the outside wall of the solid. Alternatively you may choose not to model heat transfer in the solid in which case you can as well delete the solid zone.
Old   May 3, 2009, 09:44
Eric
thanks i will have a try!
my email is daozhenxu@hotmai.com welcome to contact me !
it would be my honnor to know your email!
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
wall shadow problem paul FLUENT 5 November 16, 2013 13:46
wall shadow amar FLUENT 1 February 5, 2010 06:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
