Stop running without any errors during system coupling
Old   January 19, 2017, 22:02
Default Stop running without any errors during system coupling
Khan
khhan0543 is on a distinguished road
Hi there,
I am working on two-way fluid structure interaction based on system coupling. I have an issue that my simulation suddenly stops running without any error messages during the system coupling. It just seems like to take forever. This issue happened when I used 0.001 s of step time, but the simulation worked fine when using a longer step time such as 0.01 or 0.005 s. I would appreciate if anyone could help with this.
Thank you!
khhan0543 is offline   Reply With Quote
Old   March 7, 2017, 06:24
Lucas Ribeiro
Warlord is on a distinguished road
Have you solved? If not, check if it is a out of memory error.
Warlord is offline   Reply With Quote
2-way FSI, System Coupling error Arty Main CFD Forum 1 May 12, 2013 14:41
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
