vapor transport through membrane pores
Old   May 15, 2009, 05:18
Default vapor transport through membrane pores
Rubina Bahar
rubiname88 is on a distinguished road
I have to simulate the heat and mass transfer when vapor passes through membrane pores.it is a phenomena under membrane distillation process. This vapor will be generated as a result of evaporation from hot water.and this vapor will travel through the membrane on the other side where there is a cold surface to produe condensate. as a newbie in FLUENT can I get some ideas on where to start? like how to link the evaporation caused by difference in partial pressure between the hot and the cold side?
rubiname88 is offline   Reply With Quote
membrane distillation, vapor partial pressure
porous filtration membrane area in model catherina CFX 3 October 27, 2011 06:05
Membrane distillation system .. URGENT ashish FLUENT 0 June 9, 2008 19:03
UDF for vibrating membrane Sherif FLUENT 0 November 9, 2004 10:17
moisture transfer through membrane m. Nasif FLUENT 0 October 23, 2003 03:41
mass transfer from fluids to membrane Peter FLUENT 0 August 2, 2002 14:27
