PARSE ERROR Message when interpreting UDF in FLUENT
Old   May 24, 2009, 11:40
Default PARSE ERROR Message when interpreting UDF in FLUENT
Dhiman
dhimans is on a distinguished road
Hi friends,
I am repeatedly getting a PARSE ERROR message when I try to interpret my source file(named HTCOi.c) containing UDFs
This is what I intend to do with the UDF :-
1. Obtain Heat transfer Coef using a function DEFINE_ON_DEMAND(HTcoef1) modify(using a Correction factor) and store it in UDMI after solving for convection (GAS.msh) over a plate
2. Read another case (SOLID.msh which is a plate) and impose the HT coef stored in UDMI through function DEFINE_PROFILE(HTcoef2,t,pos)
However, when I interpret HTCOi.c i get the following error
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "C:\Users\Sushant Dhiman\Desktop\AUTOMATION_CODES\U
Fs\HTCOi.c"
Error: C:\Users\Sushant Dhiman\Desktop\AUTOMATION_CODES\UDFs\HTCOi.c: line 28: parse error.
Error: C:\Users\Sushant Dhiman\Desktop\AUTOMATION_CODES\UDFs\HTCOi.c: line 29: parse error.
Error: C:\Users\Sushant Dhiman\Desktop\AUTOMATION_CODES\UDFs\HTCOi.c: line 33: f: undeclared variable
The HTCOi.c UDF that I use is as Follows
#include "udf.h"
#include "math.h"
/* ##Definition of global variables and constants ########## */
#define tinf 400
#define CF 1 /* Correction factor */
#define ID 0 /* Domain ID to be used in ON DEMAND UDF(default interior ID=0) */
#define ZID 3 /* ID of the Zone of which HT coeff has to be used (plate_top ID=3)*/
int i;
/* ###### OBTAINS THE HT_Coeff from plate_top in GAS.msh#####*/
Thread *t;
Domain *d;
d=Get_Domain(ID);
t=Lookup_Thread(d,ZID);
real temp,q;
face_t f;
begin_f_loop(f,t)
temp=F_T(f,t); /* Obtains the Temp at the surface */
q=BOUNDARY_HEAT_FLUX(f, t); /* gets the TOTAL Heat flux vector at the surface */
F_UDMI(f,t,0)=CF*fabs(q/(temp-tinf)); /* Calculates the HT coefficient and stores in user defined memory */
end_f_loop(f,t)
/* ### IMPOSES THE HT_Coeff PROFILE ON the face in SOLID.msh ## */
Thread *t;
face_t f;
begin_f_loop(f,t)
F_PROFILE(f,t,pos) = F_UDMI(f,t,0);
end_f_loop(f,t)
I would really appreciate some help on this
Regards
Dhiman
dhimans is offline   Reply With Quote
need some basic help with fluent udf aarti sekaran FLUENT 8 February 12, 2008 00:57
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 10:19
Fluent 6.1/6.2 UDF compatability Allan Walsh FLUENT 1 April 29, 2005 11:49
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 03:07
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
