Error when starting Fluent 6.3 on Pc with lnia64 architecture |
June 4, 2009, 09:30 |
Julian Krick
Hallo,
I have a problem with running "Fluent 6.3" on my computer. I have a 64-bit, intel dual processor with OpenSuse 10.3 and installed, as root, the following file on in my "/opt/" directory : "Fluent_install_lnia64-6.3.26.sh" After the installation I added the following lines to my ".bashrc": export FLUENT=/opt/Fluent.Inc export PATH=$PATH:${FLUENT}/bin export FLUENT_ARCH=lnia64 Then, I restarted the terminal, typed "fluent" and got the following error: /opt/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 /opt/Fluent.Inc/fluent6.3.26/cortex/lnia64/cortex.3.7.3 -f fluent (fluent " -alnia64 -r6.3.26 -path/opt/Fluent.Inc") /opt/Fluent.Inc/fluent6.3.26/bin/fluent: line 4668: /opt/Fluent.Inc/fluent6.3.26/cortex/lnia64/cortex.3.7.3: cannot execute binary file Does anyone know a solution to this problem? Thanks for reading this thread, cheers Julian
grid generation: ICEM CFD 13.0 solver: CFX 13.0 |
March 15, 2010, 23:49 |
Mateusz
Hi Julian
I have exactly the same problem as you. Did you find solution? In my case I was reinstalling my system and installing once again the same fluent as previously but only this time I got the same message: /opt/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 /opt/Fluent.Inc/fluent6.3.26/cortex/lnia64/cortex.3.7.3 -f fluent (fluent " -alnia64 -r6.3.26 -path/opt/Fluent.Inc") /opt/Fluent.Inc/fluent6.3.26/bin/fluent: line 4668: /opt/Fluent.Inc/fluent6.3.26/cortex/lnia64/cortex.3.7.3: cannot execute binary file Maybe somebody could help? All the best Mat |
FLUENT 6.3 for particle deposition studies? | Prashanth | FLUENT | 14 | September 17, 2015 02:05 |
Fluent 6.3 with intel Quad core | Fluent user | FLUENT | 1 | August 31, 2008 12:37 |
Fluent 6.2 and 6.3 compatibility | Ale | FLUENT | 0 | July 31, 2008 03:47 |
starting fluent under freeBSD4.9 | Herakles | FLUENT | 0 | June 2, 2004 09:05 |
Problem starting Fluent | Ankan Kumar | FLUENT | 3 | October 28, 2002 05:33 |
