June 6, 2018, 22:18 |
The problem of conversion polyhedra mesh
wanghuo
Rep Power: 11 |
Hello friends!
I want convert tetrahedral mesh to polyhedra mesh . When I click mesh-polyhedra-convert domain the fluent prompt error: Setup conversion to polyhedra. Converting domain to polyhedra... Creating polyhedra zones. Processing face zones..................................... Processing cell zones..... Building polyhedra mesh........................ Optimizing polyhedra mesh....MPI Application rank 1 exited before MPI_Finalize() with status -1073741819 The fl process could not be started. That's why?Thank you very much! |
July 4, 2018, 12:12 |
Rep Power: 8 |
Are you sure you have enough RAM? The process is VERY memory-consuming.
Polyhedra and sliding mesh? | rockewan | FLUENT | 5 | December 1, 2018 19:07 |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 11:02 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
