Initializing fluid level on VOF model
Old   October 30, 2008, 13:55
Default Initializing fluid level on VOF model
Daniel
I'm trying to model the flow through a trough distributor, with both the top and bottom open to atmosphere. Liquid enters through a downspout. I know the theoretical average surface height, and I would like to use this as an ititial condition. If I try to break the fluid domain into 2 zones (1 for liquid, 1 for air with the interface at the expected surface level) the solver fails with Error: Floating point error: invalid number. This happens regardless of whether i'm using the VOF model or a single phase. Do you have any recommendations for initializing the domain, or a way around this error? Thanks.
Old   October 30, 2008, 15:27
Default Re: Initializing fluid level on VOF model
CDE
You can do this in 3 steps: 1) Initialise the domain with VOF = 0 for liquid. 2) Go to Adapt->Region and mark the region that is full of liquids using coordinates. 2) Go to Solve->Initialise->Patch and patch the region you marked in step 2 with liquid VOF = 1
Old   November 4, 2008, 17:20
Daniel
Thanks CDE. That seems to help.
Old   July 3, 2009, 02:05
alven
alven299 is on a distinguished road
Originally Posted by CDE
;154423
Hi CDE, how do you check whether the VOF=0 for liquid upon initializing? Thank you.
alven299 is offline   Reply With Quote
Old   July 3, 2009, 03:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can check your initialization by displaying the contour of vof before starting to iterate
It should match the value you gave in solve/initialize
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 3, 2009, 03:45
alven
thank you very much, at least I have a bit of idea on wat is going on in VOF now
Problems initializing a turbulence model srinath OpenFOAM Running, Solving & CFD 3 November 27, 2008 10:06
Define initial liquid level for VOF model Gab CFX 2 May 9, 2007 23:42
book on Level Set, focus on fluid flow phsieh2005 Main CFD Forum 3 October 11, 2006 16:17
Volume of Fluid and Level Set Huckleberry Finn Main CFD Forum 2 November 29, 1999 15:17
UDF for initializing VOF Ray Main CFD Forum 0 November 11, 1999 11:29
