Regarding about Fluent batch scripts
Old   July 3, 2009, 09:07
Default Regarding about Fluent batch scripts
CJ
solefire is on a distinguished road
I am using PBS to subscrib the job to clusters for fluent cases. But there are always some error feed back I cannot slove. Is there any one who can help me take a look at it? Thanks a lot!
1. Fluent script:
rc /data/l/users/u0062648/testcase/vf_rng/vf_rng.cas
solve/initialize/init-flow-statistics
solve/iterate 50
wd /data/l/users/u0062648/testcase/vf_rng/vf_rng50.dat
exit
yes
2. This is the feed back! Thanks a lot!
invalid command [init-flow-statistics^M]
Error: eval: unbound variable
Error Object: 50^M
solve/iterate 50^M
Invalid integer.
Number of iterations [1]
Error Object: wd
wd Invalid integer.
Error Object: /data/l/users/u0062648/testcase/vf_rng/vf_rng50.dat^M
Invalid integer.
Error Object: exit^M
exit^M
Invalid integer.
Error Object: yes^M
yes^M
Invalid integer.
solefire is offline   Reply With Quote
Old   July 5, 2009, 08:56
Monker1980 is on a distinguished road
Did you create your journal file on a Windows machine? If so, it may have included line break characters at the end of each line which the Linux/Unix cluster does not like. Try creating the file either on a Linux system or save in Notepad/Wordpad using 'unicode' formatting.
See http://kb.iu.edu/data/acux.html for more info.
Monker1980 is offline   Reply With Quote
Old   July 5, 2009, 09:28
CJ
thanks a lot! you are absolutely right! problem solved
Old   July 5, 2009, 09:39
You're welcome - glad to help.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
problem with fluent in batch mode Pat FLUENT 2 February 13, 2003 13:14
sequential batch run jy FLUENT 2 August 2, 2000 11:41
Batch File fo Fluent & Fieldview Oliver FLUENT 0 July 14, 2000 13:12
