Little question
Old   July 3, 2009, 12:35
Default Little question
Franz Roman
franzdrs is on a distinguished road
I wanted to know if there is a problem with my simulation if the residuals drop and the go up again, and down and up and down again, with an overall tendency to go down, until it finally reaches convergence to 1e-6. I mean, should the residuals drop constantly? If the oscillate, does that mean the problem is not well set up?
thanks
franz
franzdrs is offline   Reply With Quote
Old   July 6, 2009, 00:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If the residuals are decreasing, I assume you are gonna catch a convergence despite the oscillating.
But I would monitor a special variable such as force, massflow etc... and check if the monitor is also oscillating.
If yes, then maybe you are handling an unsteady problem
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 8, 2009, 12:30
Franz Roman
hi mAx,
thanks for your answer. When I posted this thread I had a case where the residuals oscillated about 4 times and finally converged (1e-6, bot not yet horizontal residuals) after around 5000 iterations. Now I am running another simulation in which I changed something in the system, nothing very special or tricky at all. the thing is now I also have oscillations with the tendency to drop, but I am already in 11000 iterations and 16 oscillations. the oscillations of all residuals are in phase and the all look exactly the same, only that slowly going down from one iteration to the next. My guess is, it will reach the 1e-6 criteria but maybe in 10000 more iterations or so. Is that also normal or ok?
I am monitoring the massflow andthe graph seems also to be oscillating but in the order of 5e-8 to -2e-7 kg/s, very small I think. My system is quite simple: a velocity inlet in the horizontal direction, air flows then into a plenum chamber and then through a porous media in the vertical direction out through a pressure outlet.
Can you explain me that about maybe my problem being unsteady? The airflow coming in is constant, the system and the grid (Hex map) is absolutely simmetric.
Thanks again.
Franz
Old   July 8, 2009, 13:13
-mAx-'s Avatar
Maxime Perelli
*you can speedup the convergence with under-relaxation's factors
*regarding the unsteady case, check the von karman vortex... straight flowfield around a cylinder (could be computed with symetries) but at specified Re, the wake is oscillating
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Static pressure at outlet - Stupid question??? Miry CFX 0 September 16, 2007 18:14
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
