July 16, 2009, 08:34 |
Highly skewed element.
EYITAYO AFOLABI
can some one please explain steps to take in resolving highly skewed element in a mesh?
Thanks for the anticipated assistance. |
July 17, 2009, 03:22 |
Maxime Perelli
Rep Power: 41 |
go back to the mesher, correct some parameters, remesh and check cells quality
In memory of my friend Hervé: CFD engineer & freerider |
July 18, 2009, 17:28 |
Highly Skew Mesh
EYITAYO AFOLABI
Can you please mention some of the parameters that needed to be change in order to correct highly skew mesh?
July 18, 2009, 22:26 |
Farhat Rasool Khan
May be you are meshing a geometry with complicated surfaces. You should decompose the domain so as to limit skewness to as small area as possible and use structured meshing. Skewness arises when the meshes get deformed near the complicated surfaces.
Farhat |
July 20, 2009, 01:27 |
Maxime Perelli
Rep Power: 41 |
Check in the mesher what is the cause of the skewness (typical: small edges, small angles etc...)
Can highly skewed elements create problem?? | Sanjay Jain | FLUENT | 1 | April 8, 2008 15:57 |
help: the volume mesh has highly skewed elements | xiaofish | FLUENT | 3 | September 18, 2007 09:51 |
what to do w/ highly skewed elements? (GAMBIT) | mike | FLUENT | 5 | June 2, 2007 22:10 |
highly skewed elements | srikanth | Main CFD Forum | 1 | February 21, 2006 08:15 |
Highly skewed elements | Hengky | FLUENT | 2 | August 11, 2005 12:17 |
