Air Lift Pump BCs
Old   July 20, 2009, 17:10
Exclamation Air Lift Pump BCs
Ramesh
ramesh.gannamani is on a distinguished road
Hi All,
I am simulating flow through an air lift pump using fluent, validating with experimental data that gives me maximum efficiency (Mw/Ma). Air is being injected radially from the bottom of the pipe and water is being sucked from bottom.
I tried mixture model with k-e turbulence model. The inlet velocity of air 10 m/sec with volume fraction of 1.I assumed the bubble diameter is radial hole diameter. When I solve it, the mass flow rate of water is coming as zero. This may be due to there is no inflow of water. Can anybody suggest me better boundary conditions.I am attaching brief description.
Thanks,
Ramesh Gannamani.
ramesh.gannamani is offline   Reply With Quote
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
air pump calculations??? VVJ Main CFD Forum 0 February 12, 2008 13:13
Airfoils and lift compared to air density and TE Jens Main CFD Forum 0 May 4, 2006 03:31
PUMP air into the container PIN TU Siemens 1 July 21, 2004 09:48
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
