December 13, 2002, 23:56 |
problems about MRF model
Hi: I am simulating a small centrifugal pump(a inlet and an outlet)using mutiple rotating reference frame .The model of my pump (only remains fluid zones and wall)cosists of two parts ,one is the rotating part which is set to a rotating reference frame ,the other is stationary part.The result is :the stationary part are ok,but the rotating part only has absolute velocity (its direction is same as the direction of rotation,maybe wrong),and I cannot find the relative velocity along the flow paths ,which is very important for me .Expecting your help!Thanks a lots!
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
MRF Model | kamal_g65 | FLUENT | 0 | September 15, 2010 20:24 |
non-linear k-epsilon model implementation problems | Saidi | Main CFD Forum | 2 | March 4, 2010 13:23 |
MRF model in Star CD | asishkg | STAR-CD | 2 | February 25, 2010 23:37 |
problem in using MRF model | haamed | FLUENT | 0 | October 13, 2009 07:18 |
