Natural Convection
Old   July 28, 2009, 23:29
Question Natural Convection
Maryam Kia shemshaki
santamary is on a distinguished road
i want simulation natural convection loop by FLUENT but i have some problem.
my result depend on intitial value?!!!
What do i?
santamary is offline   Reply With Quote
Old   July 29, 2009, 10:28
zhangming
ericguangzhou is on a distinguished road
Did you Set air density to be constant?
ericguangzhou is offline   Reply With Quote
Old   July 30, 2009, 03:16
working fluid is water & i use Boussinesq approximation for density
Old   July 30, 2009, 15:26
Chris
Chris D is on a distinguished road
What do you mean when you say that your result depends on your initial value? Do you mean that you get a different result if you initialize your solution with different values for velocity?
Chris D is offline   Reply With Quote
Old   August 1, 2009, 00:56
yes, if i put 300K for initial temperature i get in result (in temperature contour) 300k and if i put 320K for it i get 320
Old   August 1, 2009, 14:44
Chris
Have you checked the section in the FLUENT manual about natural convection to see if you have setup your simulation correctly? From what you are saying, it sounds like the temperature everywhere in the flow field is the same, meaning that there is probably something wrong with your setup. If in fact that's not what you're saying, could you please provide more information about your problem?
Old   August 2, 2009, 03:32
i'm working in natural convection loop.
The heat sink is located at an elevation higher than the source. That causes the circulating fluid, heated from bottom and cooled
from top, to flow under the influence of gravity, the difference
in fluid density between the two vertical arms being the driving
force.
heater(heat source) expose constant thermal flux and cooler(heat sink) exposed costant temperature.working fluid is water.
Old   August 4, 2009, 23:26
is there anyone?
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 18:43
Mixing By Natural Convection Processes Greg Perkins FLUENT 0 February 12, 2003 18:40
