Cavitation convergence problem
Old   September 29, 2009, 10:41
Default Cavitation convergence problem
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
i´m studying cavitation in a knife valve preceded by 3 plate-horifice devices. The geometry is 2D. I´ve done a steady, turbulent (k-epsilon) simulation to stablish a initial flow field without activating the cavitation model. After have a good convergence I´ve included the cavitation model, changing the pressure-velocity coupling to Simplec and linear pressure discretization.
I´ve been testing many under relaxation factors but I have divergence with every of them. I´ve tried unsteady solution with 0.0001s time step, but obtained the same result.
Any advice on this??
Thanks in advance
Figd84 is offline   Reply With Quote
Old   September 30, 2009, 01:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Is your time step really adapted?
try to set dt as follow:
dt= 0.5 * (min cell size)/(max velocity expected)
For info, I set dt=1e-7..1e-6 for hydraulic devices
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 30, 2009, 14:46
I´ve reduced time step, it´s iterating now... I´ll let you know the results. Thanks
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
convergence problem in comsol anderson COMSOL 0 February 24, 2008 16:54
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
convergence problem with FLUENT cavitation model Belete Kiflie FLUENT 3 February 20, 2006 10:16
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
