DPM mass balance help
Old   August 11, 2009, 10:19
Default DPM mass balance help
pinho
jpinho is on a distinguished road
hello..
I am modelling spray dryer chamber.
I have a pressure inlet boundary of air entering at 300k 30% humidity.
At the bottom of the chamber a pressure outlet.
After calculating velocities and temperatures profiles of continuous phase, I enable DPM module and inject droplets of water into the chamber.
My question is, after calculating interaction between both phases, the mass balance on fluent report should be different of zero, right? And this difference should be de mass of water I have injected, right?
The problem is I am getting strange results of very low injection mass, and sometimes it happens that the inlet boundary has more flow rate than the outlet.
any ideia?
thanks
jpinho
jpinho is offline   Reply With Quote
Old   April 25, 2014, 06:48
Maaz Ul Mosaid
maazulmosaid is on a distinguished road
Did you find solution for your problem?
maazulmosaid is offline   Reply With Quote
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
mass balance of single species antonietta FLUENT 0 November 11, 2005 11:11
Mass balance problem! JADG FLUENT 4 December 27, 2003 10:40
Mass balance of DPM (lagrangain) case) Hiranya FLUENT 2 June 4, 2002 01:03
