Y+ problem
Old   August 18, 2009, 05:33
Default Y+ problem
pipin
pipin is on a distinguished road
I've a problem with my mesh, i have Y+ > 1000 in a nozzle.
With the non equilibrium law (30<Y+<300) what do you think about the wall treatment in this condition?
thanks for reply
pipin is offline   Reply With Quote
Old   August 19, 2009, 23:34
Sean Delfel
delfel is on a distinguished road
Hi Pipin,
I believe you should refine your mesh in the areas with y+ over 300 -- the turbulence model assumes a "shape" of the velocity profile below the first grid point, which is why it is important to get it in the right location. My suggestion would be to check the y+ value using contours -> turbulence -> wall y+ in fluent and then refine your grid in gambit (or whichever preprocessor you're using). You can also use the adaption tools in fluent, but I generally don't like the changes they make and end up with convergence problems. That could be because I'm not using them properly, though.
Cheers,
-sean
delfel is offline   Reply With Quote
Old   August 20, 2009, 16:10
alekpopob is on a distinguished road
U must refine mesh at wall as your turbulence model.
It is very inportant, because viscousity calculation near wall seriously depends on wall grid condition.
alekpopob is offline   Reply With Quote
Old   August 20, 2009, 20:59
feng
chillyfeng is on a distinguished road
you can also use the near-wall model in fluent if you want to get the accurate representation of the flow in the near-wall region.
chillyfeng is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
