Multiphase Turbulence: K-E per phase
Old   August 20, 2009, 18:34
Default Multiphase Turbulence: K-E per phase
Casey
meangreen is on a distinguished road
I am confused about the different turbulence models offered by fluent for multiphase flow. I understand that k-epsilon per phase solves the k-e equations for each phase, but i dont understand if this is redundant if the granular temperature balance is turned on. What is different about solving the granular temperature balance the the k-epsilon for the particle phase? Is the k-epsilon per phase method only suitable for non-granular flows? Does the granular temperature balance have a term that accounts for the effects of turbulence of the primary phase?
Thanks!
*i am solving a dense granular phase interacting with a turbulent jet.
meangreen is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
How to activate just one phase turbulence model? Trodeme FLUENT 1 January 26, 2007 14:50
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
