February 10, 2007, 18:17 |
Dynamic Mesh, (Define_Geom) UDF
Dear FLUENT 6.2 user;
Can I use define_geom function to define a time dependent geometry? I want to model the 2D flow field around a rigid plate (or line in 2D), oscillates (in a specific angular interval) around one of its edges. with the best regards, ROOZBEH |
February 27, 2007, 02:16 |
Re: Dynamic Mesh, (Define_Geom) UDF
You're modelling a rigid plate so DEFINE_GEOM is a good macro for that. You can use it to prescribe angular velocity of the rotation, so yeah the orientation will be time dependent. I don't quite get what you mean by oscillation around the edges though, that sounds like it's a 3D problem. As far as I understand DEFINE_GEOM cannot provide relative movement between nodes(ie. non-rigid body), for that you use DEFINE_GRIDMOTION. In other words DEFINE_GEOM can only change the orientaion of a dynamic zone, and not the actual shape of it. |
August 28, 2009, 05:52 |
Define_gridmotion
#3 | |
Illya Shevchuk
Rep Power: 16 |
Thanks in advance! |
August 28, 2009, 08:28 |
Illya Shevchuk
Rep Power: 16 |
Ok, it's already done.
The macro is called DEFINE_GRID_MOTION and not DEFINE_GRIDMOTION |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dynamic mesh UDF problem | Peter | FLUENT | 2 | November 12, 2007 02:10 |
writing a dynamic mesh udf | ALPER ALBAYRAQ | FLUENT | 0 | October 24, 2005 08:41 |
Problem related with UDF for dynamic mesh | Ryan | FLUENT | 6 | April 29, 2004 09:29 |
UDF problem for dynamic mesh??? | lyf | FLUENT | 1 | April 19, 2004 06:43 |
