Difference between Ansys12 and fluent 6.3.26
Old   September 3, 2009, 14:58
Question Difference between Ansys12 and fluent 6.3.26
vishwanath somashekar
vishwa is on a distinguished road
I am running the LES with same case file and with same parameters one on local machine with 8gb memory, intel quad core with ansys 12 installed, the other machine being a high performance cluster with 8gb shared memory with 4 processors per node, the processors are amd opteron 8378.
I am seeing that the the case being run locally shows about 40 in the time/iter column, and the hpc one show about 2 mins.
Is there a major difference between the two versions of fluent?
Thanks,
vishwa
vishwa is offline   Reply With Quote
Old   September 3, 2009, 15:02
Question
Also, I have pasted here at the output at the command prompt while the simulation is running. Like I have mentioned, I am running a LES simulation using NITA (PISO). My question is why is it that I see the continuity, x-velocity, y and z-velocity residual values for some time steps and not the others..
Updating solution at time levels N and N-1.
done.
iter continuity x-velocity y-velocity z-velocity time/iter
180570 5.5657e-04 3.3878e-04 3.6513e-04 3.0427e-04 0:00:43 1
180570 1.2132e-04 1.9181e-06 2.0461e-06 1.8280e-06
Flow time = 0.103285s, time step = 109171
39 more time steps
done.
Flow time = 0.103286s, time step = 109172
38 more time steps
done.
Flow time = 0.103287s, time step = 109173
37 more time steps
Regards,
vishwa
