April 19, 2006, 10:42 |
Non-Newtonian Fluid in FLUENT.
Hello All,
Can anyone help me with setting up a flow problem in a pipe for a non-newtonian fluid (e.g. with a yield stress). Any tutorial will be appreciated. Regards, Naveed. |
August 30, 2009, 15:18 |
Robert Meroney
For laminar flow in Fluent: Choose Laminar turbulence model in viscosity, select liquid water in materials, change name, use drop down menu under viscosity and select non-Newtonian model you desire: power law, Carreau, Herschel-Buckley, or Cross model. Calculate.
For turbulent flow in Fluent: First select a turbulence model (ke, ke realizable, etc.), then use text command to go through menus as follows: /define/models/viscous/turbulent-expert then answer yes to enable turbulence for non-Newtonian fluids Now select a liquid material and the non-Newtonian options will appear under the viscous property listing. Calculate. There has been very little published using the non-Newtonian turbulence options; hence, there is no assurance that the model results are actually realistic! I suggest doing some validation for yourself on pipe flow, jets, or wall layers. |
Connecting two fluid zones in Ansys Fluent 12 | izumi11 | FLUENT | 24 | June 3, 2020 04:13 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
fluent udf, getting fluid density | mohsen zendehbad | FLUENT | 5 | January 29, 2010 12:26 |
numerical modelling of non newtonian fluid (blood) | Deepak Thirumurthy | Main CFD Forum | 1 | May 14, 2006 02:14 |
