August 30, 2009, 15:46 |
Non-Newtonaian Turbulent Flows
Robert Meroney
Fluent provides an option to solve various turbulence models while simultaneously specifying non-Newtonian fluid properties (Eg. power law, Carreau, Cross, Herschel-Bulkley, etc.). This model has recently been used to calculate flow around mixers in anaerobic digesters in the reviewed literature. I would like to convince myself that this is a viable model; hence, I have attempted to validate the protocol by reproducing various experimental and DNS data for non-Newtonian power law fluids flowing in pipes. The experimentalists report velocity profiles, turbulence components, pressure drops, shear, etc.
First, I succesfully reproduced Laufer's turbulent pipe flow Newtonian fluid data using the RMS model to convince myself I was using Fluent properly. Results were VERY good in all respects. Then I have attempted to replicate the DNS study by Rudman et.al. (2004) J. Non-Newtonian Fluid Mech, 118, pp 33-48 where they predicted velocities and turbulence using DNS and compared to shear-thinning CMC solution data. I used their specifications for viscous properties, RMS and ke-realizable models, very fine grids near the wall (similar to earlier Laufer simulation...ie. y+~O(1)), and iterated to residuals below 10^-4. The results produced too high pressure drops, too large wall shears, and inappropriate u', v', and w' behavior. I then attempted to replicate the laser-doppler measurements of Pinho and Whitelaw (1990), J. Non-Newtonian Fluid Mech, 34, 129-144. Results were similarly dismal. Has anyone had a better experience? Can you share details? Can you suggest what my problem might be if you have had better success? Thanks. |
non-newtonian, turbulent pipe flow |
time step for turbulent flows | vishnu | FLUENT | 0 | December 13, 2006 01:28 |
Turbulent Decay in Strongly Accelerated Flows | Jonas Larsson | Main CFD Forum | 3 | April 29, 2003 06:32 |
About low Re number turbulent flows | gorka | Main CFD Forum | 13 | April 2, 2003 05:19 |
calculating recirculating turbulent flows with k-e | Abhijeet Vaidya | Main CFD Forum | 10 | November 18, 2002 08:21 |
CFD of turbulent flows | raj calay | Main CFD Forum | 23 | April 23, 1999 05:03 |
