k-omega turbulence model: 1 vs 2 order solution
Prev Previous Post   Next Post Next
Old   August 31, 2009, 14:57
Default k-omega turbulence model: 1 vs 2 order solution
Silvia
Manucia is on a distinguished road
I am modelling film cooling on a blade leading edge.
I got a good solution with ke realizable turbulence model. Then I refined the grid so that y+ is less than 5 and I set the kw SST turbulence model.
I can get convergence only with the first order scheme solution in the dissipation rate. When I shift to the second order solution, omega residuals jump and suffer for high oscillation.
Do you have any suggestion to fix the problem?
Thans in advance
Good work to everybody
Silvia
Manucia is offline   Reply With Quote
Getting steady-state solution for turbulent model? Kwontona FLUENT 0 February 23, 2007 17:14
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
Turbulence model equations Vidya Raja FLUENT 1 September 18, 2006 00:09
HELP!! Prandtl numbers in RNG k-e turbulence model maoasis FLUENT 0 April 24, 2006 10:51
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
