August 31, 2009, 15:57 |
Adapt-gradient
vishwanath somashekar
Rep Power: 17 |
i am running a LES simulation on a cluster. I have ran it for some time now and I wanted to adapt gradient based on velocity. Here is how i did that.. On a local machine, I Read the .cas file Read the latest .dat file Then did the adapt -gradient based on velocity and computed the max and min values. then gave the threshold value as about 10% of the maximum value. there were a whole bunch of cells which were modified. Here is what I didn't not understand. How do I restart the case on the cluster. I got a segmentation violation when i did the following. On the local machine, after adapting the grid, I save the case file and the data file and the then copied to the computer cluster. Is there a way of doing this adapt-gradient in batch mode? As always, thanks a tonne.. vishwa |
Pressure Gradient in channelOodles | sega | OpenFOAM Running, Solving & CFD | 14 | August 12, 2009 06:21 |
can I use static enthalpy gradient to describe dT | Jay | CFX | 0 | August 6, 2008 23:01 |
Adapt gradient and time plot. | Sham | FLUENT | 2 | April 14, 2005 12:43 |
How to compute gradient for non-orthogonal grids? | Paul Hsieh | Main CFD Forum | 3 | November 11, 2003 04:52 |
pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 10:52 |
