Help on accessing volume fraction in mixture model
Old   April 20, 2009, 14:14
Default Help on accessing volume fraction in mixture model
Aditya Chunekar
achuneka is on a distinguished road
I am writing a UDF that involves volume fraction for Unsteady RANS simulation with cavitation model turned on.
I define a user defined memory variable and use the following snippet of code to access it.
DEFINE_EXECUTE_AT_END(udf_name)
........ /* All the definitions */
d=Get_Domain(3); /* Vapor Phase domain
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,1)=C_VOF(c,t);
end_c_loop(c,t)
(This is just to show how I access C_VOF.. I perform some other operations on it)
I get the value of C_UDMI(c,t,1) as 0 everywhere when the volume fraction of phase 2 varies from 0 to 0.4.
Can someone please help me on the same. Thanks
achuneka is offline   Reply With Quote
Old   April 20, 2009, 15:03
Aditya Chunekar
I think the problem is with C_UDMI, since I can modify the values of volume fraction using C_VOF variable.
I guess the problem is def of C_UDMI for the mixture domain. Is there any way to define a C_UDMI for a phase ?
Old   April 20, 2009, 15:57
Aditya Chunekar
I found something strange.
The initial contours of void fraction show the values in the range of 0 to 0.4
thread_loop_c(t,d)
begin_c_loop(c,t)
if(index==1)
C_UDMI(c,t,1)=C_VOF(c,t); /* >>>>> Over here C_VOF(c,t) is approx 0
C_VOF(c,t) = 1 ; /** Some arbit modification
end_c_loop(c,t)
Now if I check out the contours of volume fraction for phase 2 it shows 1 everywhere... !
So somehow C_VOF does not get the initial data on void fraction....
Am i doing something obviuosly wrong ? pls let me know ..
Old   April 21, 2009, 11:30
cfdpinku is on a distinguished road
hello aditya,
i hope you are aware that there are some special multiphase macros avaialble.
i am sure your required domain is not passing with get_domain.
can you please try once with domain_sub_domain.... you can find more details on this in UDF manual.
i hope fluent support can help you on this.
cfdpinku is offline   Reply With Quote
Old   April 21, 2009, 13:02
Aditya Chunekar
Thanks,
But the fact that I am able to modify the value of volume fraction of phase 2 through the same loop means that I am passing the phase domain to the loop. Somehow the current values are not being accessed.
I have contacted Fluent support.. Hope they help me on it
Old   April 22, 2009, 11:42
i hope domain_id =3 what you have used is picked from define->phases, for vapour phase. since domain id are not necessarily sequential. if this is correct, would you mind sharing sample case with me. i can help you on that. i have tested at my end it works fine.
Old   April 23, 2009, 13:30
Aditya Chunekar
cfdpinku,
Cannot upload the file over here. Exeeds the file limit
Can you please pm me your email ed ? The total size is around 4 mb
Aditya
Old   September 4, 2009, 06:21
asif nazir
asifnazir is on a distinguished road
hi u should go into subdomain thread then it work
asifnazir is offline   Reply With Quote
Old   September 4, 2009, 06:22
Smile
asif nazir
THREAD_SUB_THREAD look this macro from the manual
udf: volume fraction gradient in eulerian model jwwang FLUENT 22 April 15, 2015 06:27
Weighted average volume fraction Yasser FLUENT 5 April 11, 2015 08:25
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Volume Fraction in VOF model Saima Main CFD Forum 2 April 12, 2009 19:22
UDF for the mixture model khar nab FLUENT 0 July 31, 2008 06:29
