how to draw camber line of an airfoil in Gambit
Old   July 28, 2007, 00:28
Default how to draw camber line of an airfoil in Gambit
Muhammad Usman Qureshi
How to draw camber line of an airfoil in Gambit. I have only coordinates of the upper and lower surfaces of the airfoil.
Old   September 15, 2009, 19:40
Post Draw curve on gambit!!!
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
You just bring your coord to note pad=>> make matrix of its coord ==> from left to right is X-coord, Y-coord, Z-coord. Don't forget to initiate them for GAMBIT==> write the number of coord and then the number of your matrix (it will be the number of line you have).
here is the example
__________________________________________________ _____________
36 1
1.000000 0.001600 0
0.950000 0.012400 0
0.900000 0.022900 0
0.800000 0.042800 0
0.700000 0.061000 0
0.600000 0.077100 0
0.500000 0.090500 0
0.400000 0.100200 0
0.300000 0.104800 0
0.250000 0.104400 0
0.200000 0.101300 0
0.150000 0.093400 0
0.100000 0.078000 0
0.075000 0.066400 0
0.050000 0.051300 0
0.025000 0.031700 0
0.012500 0.019300 0
0.000000 0.000000 0
0.012500 -0.005000 0
0.025000 -0.004200 0
0.050000 -0.001000 0
0.075000 0.002800 0
0.100000 0.006800 0
0.150000 0.014500 0
0.200000 0.021700 0
0.250000 0.028200 0
0.300000 0.033300 0
0.400000 0.038500 0
0.500000 0.038600 0
0.600000 0.035000 0
0.700000 0.028600 0
0.800000 0.020200 0
0.900000 0.010000 0
0.950000 0.004400 0
1.000000 -0.001600 0
__________________________________________________ ______________
36 is number of point you have
1 is number of matrix you have (it can be number of edge)
then save it to your directory ==> run GAMBIT ==> click FILE ==> chose IMPORT==>ICEM INPUT==> chose file you have saved==>on geometri to create select edge==> OK.
You will have airfoil !!!
Try it!!!
teguhtf is offline   Reply With Quote
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 15:41
Help needed with Cornell's Gambit airfoil tutorial AW FLUENT 6 February 26, 2010 22:42
Help needed for airfoil mesh creation using GAMBIT Alagesanj FLUENT 2 October 20, 2008 11:39
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
