boundary conditions
Old   September 30, 2009, 16:30
Default boundary conditions
Pavel O is on a distinguished road
I have a problem with bc 'pressure outlet'. When the flow reaches the edge of domain with this bc the process is not converged. What should be set for this bc?. Could you please helop me with this.
Many thanks
Pavel O is offline   Reply With Quote
Old   October 1, 2009, 13:10
Tim Maguire
timjm is on a distinguished road
I used to have that problem too.
You can either re-mesh at that outlet so it is more refined, or try and relax your tolerances.
I would try the tolerances first and then let it come to a converged solution.
Also, sometimes it just takes a while for the pressure outlet to have convergence at all the nodes.
timjm is offline   Reply With Quote
Old   October 1, 2009, 13:32
Many thanks,
I will try to do both. As I understood the mesh should be more fine on the pressure outlet? In my case it is slightly coarser.
Old   October 1, 2009, 16:30
Default pressure bc
mangal
owais70 is on a distinguished road
Check if you have reverse flow at the outlet. Add a length/domain at the outlet.
owais70 is offline   Reply With Quote
Old   October 2, 2009, 08:49
I set momentum boundary condition 'pressure gauge' to -10, and I had no back flow. I tried to extend domain but only effect I got it was extend of time of converged process. In some cases it helps and after some time process is converged again, but not every time.
Many thanks
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 04:44
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
