October 20, 2009, 12:38 |
Normal velocity at the symmetry boundary
Hi, I am new to Fluent but have some background on fluid mechanics. I notice a problem in Fluent and don't know how to explain it. I have a 3D k-e model with a symmetry boundary. The velocity normal to this boundary should be zero according to the definition of symmetry, but the converged solution shows none-zero normal velocity exists on this surface. A similar case is the OUTFLOW boundary. By definition, OUTFLOW boundary should have zero normal flux, but I observed none-zero normal velocity gradient in a contour plot on the surface. Could anyone explain the reason please?
regards, Steve |
October 26, 2009, 06:52 |
Krishna
Rep Power: 16 |
Steve,
When a boundary is defined as symmetric, the gradients of all the properties normal to it will be zero. You are misunderstanding the properties with its gradients. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Opening BC: Normal to boundary | Jan Ramboer | CFX | 3 | September 21, 2007 15:06 |
The behavior of droplets at the symmetry boundary | SJLee | Siemens | 0 | April 17, 2007 01:50 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
